by n502pd » Wed Oct 31, 2018 12:55 pm
I talked with uAvionix support this morning, and I was told that the skybeacon will function with no problems at all with the stx 165 xpndr. Also, that the wing tip mount for skybeacon does have to have an unobstructed view of the sky, vertically, for gps, which is what I already knew. Others , however have indicated that the blade antenna on the skyview needed an unobstructed view of the xpndr antenna. It does not, and "..had nothing to do with that antenna." I also suspected that, but needed to ask anyway. So, since my nav light mounts are in the appropriate position for the nav lights, I should have no trouble with either the skybeacon and stx 165 install, setup or functionality. As these kind of things go, plans sometimes run off with the mice, and require alternate methods to get them back!I will continue posting how things progress and As of now I will move forward as soon as the CFO releases the funds!!Thanks to all for any and all comments!
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
