Murray Parr wrote:Yes, My glare shield is the same. I am sure it's the way it was manufactured, probably not quite precise where it is curved. I haven't figured out a solution yet but will most likely put up with it as the instrument panel helps keep it close to where it should be, speaking of which, the panel doesn't quite fit properly either so I had to allow the attach angle to take up some of the space around the curve
