Postby DCASonex » Thu Oct 11, 2018 1:39 pm
Depends on your legs, and seat option. Made mine just deep enough to house standard circuit breakers, 1-5/8 or 1-3/4" if memory is correct.
DCASonex
Postby Rofomoto » Thu Oct 11, 2018 5:14 pm
DCASonex wrote:Depends on your legs, and seat option. Made mine just deep enough to house standard circuit breakers, 1-5/8 or 1-3/4" if memory is correct.
Thanx Dave. Is your seat lowered?
1735
Longassproject
Rofomoto
Postby WesRagle » Thu Oct 11, 2018 8:12 pm
Hi Billy,
I'm not Dave but ... I lowered the seat in my Sonex. Then I sat in it and *did not* like it. Changed back to standard seat. If you lower the seat your knees end up higher I think. That means less sub panel space.
YMMV.
Wes
Wes Ragle
Onex #89
Conventional Gear
Long Tips
Hummel 2400 w/Zenith Carb
Prince P Tip 54x50
First Flight 06/23/2020
42.8 Hrs. as of 10/30/21
WesRagle
Postby Rofomoto » Thu Oct 11, 2018 8:24 pm
WesRagle wrote:Hi Billy,
YMMV.
Wes
I agree Wes. I’m 5’11 and did not lower the seat. So I think 1 1/2” lower panel is it.
1735
Longassproject
Rofomoto
Postby DCASonex » Fri Oct 12, 2018 8:21 am
Bill,
Mine does not have the lowered seat, but my legs are short. (Not so short that knuckles drag on ground) Lowered seat puts one's butt further back and you end up sitting straighter, but I am long in the waist and wanted a more reclining position. Also have custom contoured seat back upholstery that puts butt further forward, and with Clarity Aloft's head set, I just clear the canopy. For me, the notched seat back support of the B model looks like an improvement that could be incorporated into the A series if needed.
DCASonex
Postby Rofomoto » Sun Oct 14, 2018 9:54 am
Rudder pedal material
1735
Longassproject
Rofomoto
Postby racaldwell » Mon Oct 15, 2018 11:44 am
Here's a picture of cable diff. brakes. At least this is one way to do it.
Rick C.
Xenos 0057
racaldwell
Postby Rofomoto » Mon Oct 15, 2018 12:21 pm
Rick. Great pic thanx for the help! Billy
1735
Longassproject
Rofomoto
Postby Rofomoto » Wed Oct 17, 2018 1:55 pm
Welding time!!
1735
Longassproject
Rofomoto
Postby Rofomoto » Wed Oct 24, 2018 1:09 pm
1735
Longassproject
Rofomoto
Return to Photo Album
Users browsing this forum: Bing [Bot] and 1 guest
