by MichaelFarley56 » Thu Apr 18, 2013 8:41 pm
Hi Frank,
If I had the option I would switch to a top mounted oil cooler simply to reduce the number of oil lines that run from the oil pump to the cooler. Plus, like you said, it may work a little better.
Unfortunately, I'm not sure how big of a cowling blister you would need to graft onto the cowling in order to make clearance for the cooler. Also, you will probably still need to open a spot in the cowling to allow air to pass over the bottom of the engine. The manual says that is an important part of cooling.
The good news is you should be able to make your engine "Sonex stock" by changing to the Sonex style oil pump. You may be able to call Kerry at Sonex and ask about the factory Waiex; I think they switched to the upper cooler when they added the turbo system. They may be able to help!
