Gordon wrote:Sonex vs RV-12...........?
The RV-12 will cost you more to build than the Sonex..........HOWEVER....the re-sale is so much higher with the RV-12 (or any RV for that matter) than the Sonex, that you would still come out ahead with the RV.
Something to consider.
Gordon...Onex....Hummel 2400.....(multiple RV builder/flyer)
Gordon wrote:Having said that........if you are building a Sonex because you WANT to "build it" and enjoy that experience than that is a legitimate reason to do it.
bvolcko38 wrote:Regarding oil pressure, I too, blew out my oil cooler in the first 3 seconds of my first engine start up. My second engine startup blew out my oil filter gasket. Later, I found, with a mechanical gauge, I was getting close to 200 psi of oil pressure! I went to the hardware store and found a similar sized, but much weaker oil pressure relief spring for the rear plunger. I now have about 90 psi at cruise. Still a bit scary with a cold startup ..180 psi till the oil warms a little.
BV
Users browsing this forum: Bing [Bot] and 72 guests
