bvolcko38 wrote:I'm using the number 2 needle with 90 octane non ethanol.
Onex107 wrote:I don't know what my fuel flow is, and , I don't care. It's somewhere between 3 and 4 gals. per hour. The spark plugs tell the story. If they are sooty, you are obviously too rich and if they are clean you are anywhere from normal to too lean. The temps are the clue to too lean. I suspect, from 250 hours of flying with the Aerovee, that wot, 3000 plus, will put you in a leaner state than 2900. I think I find that reducing the rpm also changes the mixture to hot cylinders. Not sure, but it works. Has anyone calculated the area of the opening as it goes to maximum. Does it go over maximum?
Users browsing this forum: No registered users and 52 guests
