Very hot number one cylinder EGT
Re: Very hot number one cylinder EGT
Postby bvolcko38 » Wed Sep 05, 2018 6:22 am
Mike,
I leaned, slowly, until the engine ran smooth. Any richer and it runs rough.
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Postby XenosN42 » Wed Sep 05, 2018 9:43 am
mike.smith wrote:
bvolcko38 wrote:These are the CHTs from the same flight.
1 and 3 are hot. Probably need to put a little baffle on the front of 2 and 4 to deflect more air to 1 and 3
Based on that information I'm pretty sure you're running too lean. You may also need to retard your secondary ignition a bit. I likewise had a couple cylinders that looked "good" and a couple very hot. It doesn't matter so much that you have two that don't look bad. The voice of experience speaking :-)
I agree with Mike. I had a similar situation with a large spread between the hottest and coolest clylinders. It was caused by running too lean.
-- Michael
-- Michael
OneX N169XE
XenosN42
Postby lutorm » Wed Sep 05, 2018 5:51 pm
mike.smith wrote:Based on that information I'm pretty sure you're running too lean.
On which cylinders? ;-)
On our engine, if the mixture was adjusted so the back cylinders didn't run lean, the fronts became so rich so as to barely run...
lutorm
bvolcko38 wrote:I leaned, slowly, until the engine ran smooth. Any richer and it runs rough.
What did the 4 EGTs do when you did that?
lutorm
Postby bvolcko38 » Thu Sep 06, 2018 8:15 am
1 and 3 got hot.
Bill Volcko XNS0068
V6
First hole 4/1/16
bvolcko38
Postby lutorm » Thu Sep 06, 2018 4:13 pm
bvolcko38 wrote:1 and 3 got hot.
What about 2 & 4?
lutorm
Postby bvolcko38 » Fri Sep 07, 2018 2:49 pm
2 and 4 stay cool
Bill Volcko XNS0068
V6
First hole 4/1/16
bvolcko38
Postby lutorm » Fri Sep 07, 2018 3:19 pm
bvolcko38 wrote:2 and 4 stay cool
They did not change at all? That seems quite strange.
If you continue leaning from the point where the roughness goes away, do the EGTs on the hot cylinders continue climbing or do they drop. Do the cool cylinders start climbing?
The only thing I can imagine is that the front cylinders are running so rich that their EGTs basically don't change. But at *some* point, they have to start climbing as you lean out. Knowing where that is in relation to where the rear ones peak will tell you something about how uneven your mixture is.
lutorm
Postby bvolcko38 » Sun Sep 09, 2018 7:54 am
After checking, with a timing light, and comparing to the fixed primary ign, the secondary was very much advanced... about 40 degrees btdc! Fixed now but symptoms are the same
Bill Volcko XNS0068
V6
First hole 4/1/16
bvolcko38
Postby mike.smith » Sun Sep 09, 2018 1:47 pm
Which needle are you currently using? If you're not getting positive results then you might try another needle. I ran with the #2 for too long, trying to sort things out. I changed to the 2.5 needle and after a few trial and error adjustments got the numbers I needed.
Users browsing this forum: No registered users and 32 guests
