by Darick » Tue Jan 26, 2021 11:46 am
I changed from the "slick" profile to the standard 5.00 x 5 tire size. There is NO difference in weight. They both weigh 6 lbs each.
The small factory tire weighs 3.4 lbs. (no picture of the factory tire). The wheel pants do not fit with the 5.00 x 5 tires so that is the next project.
- Attachments
- IMG_4785.jpeg (47.76 KiB) Viewed 43334 times
- IMG_4782.jpeg (55.42 KiB) Viewed 43334 times
- IMG_4781.jpeg (40.62 KiB) Viewed 43334 times
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
