Rough running on primary (Magnetron) ignition
Re: Rough running on primary (Magnetron) ignition
Postby rick9mjn » Mon Sep 03, 2018 10:24 am
.all earlier things listed ,are good things to check,
and please re-read the one listed by "by sonex1374 » Fri Aug 31, 2018 5:45 pm"
.my suggestion ; is about your question =.
"""Is there a way to check the coils with an ohmmeter? I understand these are Briggs and Stratton pn 394891""
my small idea is ;; yes thay can be checked with a ohmmeter , the ( how to )
is in most small engine "lawn mower" manuals....
also online price for the coil ""Briggs and Stratton pn 394891""" is less than 25 dollars
as a side story ; both times i went to my local "small engine shop" to buy a coil ,
they said the coils "do not often" go bad ,
but they always had one in stock..
......good day /rick
rick9mjn
Postby bvolcko38 » Fri Sep 07, 2018 8:10 am
OK.
Ran separate ground wires to magnetrons...no change
Used a timing light to make a random index mark to find where 28 degrees BTDC is, then from that mark, checked secondary CDI ignition timing... wow it was about 40 degrees BTDC!!!! even though I set it according to picture in Aerovee manual.
Set cdi ignition to 28 degrees BTDC using timing light and index mark from primary ignition...
Now there is little to no drop in rpm during mag check. Also carb need further enriching due to timing change.
I'll have this thing running like a swiss watch soon...
BV
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Users browsing this forum: No registered users and 44 guests
