by bvolcko38 » Thu Aug 30, 2018 8:28 am
The primary ignition runs rough. Secondary smooth as silk. I thought it might be a sparkplug problem, so I installed new top plugs. Both front plugs were black with soot and both rear plugs were clean. The front plugs fire off the top coil. Is it possible that coil is weak? The engine doesn't skip, it is just rough. I started the engine, cold, on just the primary ignition. ran it for a few minutes and checked the exhaust headers, they were all 4 pretty much equally hot .
Is there a way to check the coils with an ohmmeter? I understand these are Briggs and Stratton pn 394891
Any ideas?
Frustration is setting in.
BV
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
