Rough running on primary (Magnetron) ignition
Postby bvolcko38 » Thu Aug 30, 2018 8:28 am
The primary ignition runs rough. Secondary smooth as silk. I thought it might be a sparkplug problem, so I installed new top plugs. Both front plugs were black with soot and both rear plugs were clean. The front plugs fire off the top coil. Is it possible that coil is weak? The engine doesn't skip, it is just rough. I started the engine, cold, on just the primary ignition. ran it for a few minutes and checked the exhaust headers, they were all 4 pretty much equally hot .
Is there a way to check the coils with an ohmmeter? I understand these are Briggs and Stratton pn 394891
Any ideas?
Frustration is setting in.
BV
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Re: Rough running on primary (Magnetron) ignition
Postby kmacht » Thu Aug 30, 2018 12:36 pm
How many hours on the engine and did it just suddenly show up or has it been a gradual increase in roughness?
#554
kmacht
Postby mike.smith » Thu Aug 30, 2018 8:06 pm
Is this a new engine or has it been running for a while? I stupidly had my flywheel magnet installed backward and got the same symptoms you are describing. But if you've been running your engine for a while then that wouldn't be the problem.
Postby bvolcko38 » Fri Aug 31, 2018 5:42 pm
Brand new engine. First flight last week
Bill Volcko XNS0068
V6
First hole 4/1/16
bvolcko38
Postby sonex1374 » Fri Aug 31, 2018 7:45 pm
Bill,
Check out the gap between the magnatron unit and the flywheel trigger magnet. Also verify that the magnet is oriented properly. It can be confusing, so follow the instructions carefully. If neither of those things show any problems, you might check over the spark plug wires and tips/boots to see any trouble spots. You could have some slight damage to the wires or deformed tips that have gone un-noticed.
Black plugs are common early on while you get the carb tuning perfected, and you should plan on leaning the mixture "brutally lean" on the ground to keep things clean inside. Sooty plugs might cause rough running, but are not necessarily a problem.
Jeff
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Postby kmacht » Fri Aug 31, 2018 9:49 pm
If you don't already and the other suggestions dont work, run individual ground wires between the engine and each magneteon. The red annodize can sometimes cause a bad connection and weak ground.
#554
kmacht
Postby Sonex1517 » Fri Aug 31, 2018 10:22 pm
One other idea to add. I had a plug lead melt against a head and cause this exact behavior on my third test flight.
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Postby bvolcko38 » Sat Sep 01, 2018 3:46 pm
Will definitely run separate ground wires to magnetrons. And will check magnet polarity. All else seems good Sometimes worse than others 5 flights so far,,,, takes time tosort these things out I guess.
BV
Bill Volcko XNS0068
V6
First hole 4/1/16
bvolcko38
Postby lutorm » Sat Sep 01, 2018 4:50 pm
bvolcko38 wrote:Any ideas?
Do you have 4 EGTs? It makes troubleshooting things like this infinitely easier.
lutorm
Postby bvolcko38 » Sun Sep 02, 2018 10:21 pm
Yes 4 egts
Bill Volcko XNS0068
V6
First hole 4/1/16
bvolcko38
Users browsing this forum: No registered users and 26 guests
