Arnieb wrote:I bought a Sonex that was completed but wasn't flying. I have 7 hours in the air with it, there has been a few problems that I was able to straighten out. The latest is the engine started running ruff when I was in the air so I thought I better get back on the ground. When I was coming in for the landing fuel started coming out of the fuel vent, I am wondering if the way the builder had placed the vent was correct if not is that why I built pressure in the tank. He has the vent facing forward just above the fuel door.
peter anson wrote:In this photo you can see that my vent is easily more than 4" high. It would leak fuel on quite gentle descents if I had more than about 50 litres (13 gallons) of fuel.
When you did your gentle descents, would that be with the throttle pulled back to idle? I ask because I usually run an absolute minimum of 1500 rpm in a descent (all my approaches are with power until a very short final) and even with a near full tank, there is no fuel spill.
