by Onex107 » Tue Aug 21, 2018 1:34 am
I don't think the Aerovee is doing something it wasn't designed for. It's designed to produce a certain amount of HP and it does that when you ask it to. In a car it never operates over 30% of it's rated HP. Every airplane engine is asked to put out 100% for a short period of time and around 70% during cruise. It ain't gonna run 200 thousand miles like that. The certified engines are recommended for overhaul at 2000 hours and it's not unusual for them to need a "top" overhaul half was through. That's the equivalent of 70 K in a car. Those of you that like higher HP and can afford to buy it, more power to you. Every airplane performs better with more HP. You haven't spent much time in a C-120, C-140 where 200 ft/min is pretty good. The Aerovee is the most bang for the buck. If you are uncomfortable assembling the engine, all it takes is money to go another route. You just have to put your confidence in someone else to build it and who is going to do the maintenance when some thing major goes wrong. For 25 years I depended on an A&P to "garruntee" my engine was O.K. and when it shot me down it was because he missed a simple inspection that would have taken 15 minutes, and it cost me $ 4K to fix it, plus the $ 1K for his inspection. No more. I'm the master of my own fate now. No one, but no one knows more about that engine than I do, and it's performing like it was designed to do.
