Aircraft Lighting
Aircraft Lighting
Postby pfhoeycfi » Thu Aug 02, 2018 8:01 am
I am curious as to what type of aircraft lighting builders are installing, ie landing & nav/pos/strobe. I'm getting closer to skinning the wings and need to start consider pulling wire to the tips. Also what is being used for conduit in the wings?
thanks again...lots of great info here,
Doylestown, Pa
SNB0021 in progress
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Re: Aircraft Lighting
Postby Bryan Cotton » Thu Aug 02, 2018 10:43 am
I used Whelen Orion 600's.
http://m.aircraftspruce.com/catalog/elp ... kkey=22748
For landing lights I used Fresh Aero:
https://www.freshaero.com/m.tlrlight.html
For conduit I used a couple runs through the existing 1/4" tooling holes in the forward rib.
Postby pfhoeycfi » Thu Aug 02, 2018 10:52 am
Did you pull your conductors thru poly or plastic tubing?
thanks,
peter
Peter Hoey
pfhoeycfi
Postby Bryan Cotton » Thu Aug 02, 2018 2:36 pm
1/4" OD poly tubing.
Postby mike.smith » Thu Aug 02, 2018 10:34 pm
I have wingtip LED nav/strobe lights from Aveo Engineering. Landing light is a Duckworks with HID lamp (no longer available). Note that if you plan to fly at night your lights MUST be TSO'd units to be legal (one of the only things on an experimental that needs to have a TSO). And if you install on the wingtips you need to put them on pods so they meet the angle requirements for viewing: https://www.whelen.com/pb/Aviation/Syst ... ystems.pdf.
I highly recommend you run dedicated ground wires from your lights back to your ground block and not use the airframe as a ground path.
Postby pfhoeycfi » Thu Aug 09, 2018 6:09 am
Ok great. Have builders been running shielded or non shielded to the wing tip lights and landing lights? I'm think an 18/4 to tips and an 18/2 to the landing light.
Peter Hoey
pfhoeycfi
Postby Bryan Cotton » Thu Aug 09, 2018 7:07 am
I used shielded wire. Makes it like pulling a single wire through the conduit.
Postby tx_swordguy » Thu Aug 09, 2018 8:40 pm
just a quick question. I am a sport pilot and cannot fly legally at night. I have nav lights and strobe lights on my sonex. My nav lights are not functional at this time and I have not had time to investigate. Is that something that MUST be operational if it is installed (for condition inspection) or is it an optional item since it is not required to be on the plane to begin with?
Mark
Mark Whiddon
T25 Aero Estates
Sonex N889AP
jabiru 3300 solid lifter
tx_swordguy
Postby mike.smith » Thu Aug 09, 2018 8:42 pm
pfhoeycfi wrote:Ok great. Have builders been running shielded or non shielded to the wing tip lights and landing lights? I'm think an 18/4 to tips and an 18/2 to the landing light.
My setup did not require shielded wires and so I did not use any. No issues in 4 years.
Postby mike.smith » Thu Aug 09, 2018 8:45 pm
tx_swordguy wrote:just a quick question. I am a sport pilot and cannot fly legally at night. I have nav lights and strobe lights on my sonex. My nav lights are not functional at this time and I have not had time to investigate. Is that something that MUST be operational if it is installed (for condition inspection) or is it an optional item since it is not required to be on the plane to begin with?
Mark
I don't know the "legal" answer, but my DAR insisted if if was on/in my plane then it had to be functioning. And even though an ELT is not a requirement during the 40 hour single pilot test phase, he said I had to have a functioning unit installed or he would put in my operating limitations that the plane had to be reinspected prior to the 40 hour sign off. And that would be another $250. So I went ahead and put it in :-)
Return to Electrical System
Users browsing this forum: No registered users and 20 guests
