SNX-F10-06 hook mount
Postby Rofomoto » Fri Aug 03, 2018 12:19 pm
I don’t need this if using Bowden cable trim correct? Thanx billy
1735
Longassproject
Rofomoto
Re: SNX-F10-06 hook mount
Postby peter anson » Sun Aug 05, 2018 8:02 am
Not Correct. The elevator isn't mass balanced so even if you are using the cable operated trim tab, you need some sort of spring balance for the elevator. SNX-C01 mentions a bungee to support the elevator level or slightly down and warns you not to cut it too short. I used a small pulley on one end and a bungee from the other end going around the pulley and going back to an adjustable cleat, a small yacht fitting, so that the bungee is easily adjustable.
peter anson
Postby Rofomoto » Sun Aug 05, 2018 10:01 am
peter anson wrote:Not Correct. The elevator isn't mass balanced so even if you are using the cable operated trim tab, you need some sort of spring balance for the elevator. SNX-C01 mentions a bungee to support the elevator level or slightly down and warns you not to cut it too short. I used a small pulley on one end and a bungee from the other end going around the pulley and going back to an adjustable cleat, a small yacht fitting, so that the bungee is easily adjustable.
Thanx Peter.. should have looked farther down the line. Thanx again
1735
Longassproject
Rofomoto
Return to Sonex Plans
