by SonexN76ET » Wed Aug 01, 2018 4:18 pm
Check out this article on propeller tracking:
http://www.ultralightnews.com/pilotslounge/propellertracking.htmYou may want to let your propeller sit untorqued for an hour for the wood to expand back to its original shape before starting the tracking process.
When you do your final torque values do not forget to add the torque for the friction of the nylon on the stop nuts (about 2 ft lbs).
Jake
Sarasota, Florida
