by pfhoeycfi » Tue Jul 24, 2018 3:37 pm
Any suggestions on when to rivet the wing rib gussets to the ribs? The order of assembly seems to indicate to do so prior to putting the ribs on to the spars for updrilling thru the rib flange and spar web. That is fine but I anticipate that it will be difficult to then clean and debur the holes (between the gusset and rib flange) used to attach the rib to the spar.
peter
SNB0021 in progress
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
