Best builder log sites?
Postby SP1 » Thu Jul 19, 2018 12:27 am
Anyone have recommendations for build logs to check out? I'm looking for ones that best illustrate the build process and help detail the potential gotchas. I'm aware of Sonex604.com (jeff's). Any other sites that stand out for completeness and thoroughness? Thanks!
SP1
Re: Best builder log sites?
Postby wlarson861 » Thu Jul 19, 2018 12:38 am
One I used other than Jeff's site is Bob Meyers. he was about a year ahead of me in his build but has a lot of information and pictures.
http://n982sx.com/
Bill Larson
N861SX
wlarson861
Postby Rynoth » Thu Jul 19, 2018 5:53 pm
I'll volunteer mine, it's received a lot of positive responses and I feel like I kept a lot of good layman details in it right up until the final stages of the project (still in 99% completion limbo.)
http://www.rynoth.com/wordpress/waiex/
Postby sonex1678 » Thu Jul 19, 2018 9:51 pm
I recommend also going to the Kitlog Pro website and seaching under type acft, sonex. You will find many builder logs, and can look at multiple examples of work by multpile builders, both in progress and completed.
Douglas B Scripture
Sonex 1678
sonex1678
Postby kmacht » Thu Jul 19, 2018 10:14 pm
Mike Smith has a good one for those scratch building. I dont have a link but a quick google of his name and Sonex will find it.
#554
kmacht
Postby SP1 » Fri Jul 20, 2018 5:14 pm
Thanks very much. These are all very well illustrated!
SP1
Postby rizzz » Fri Jul 20, 2018 6:29 pm
I’ll plug mine here as well: http://www.mykitlog.com/rizzz/
Lots of pictures under the empennage section which might help you with your current issues.
rizzz
Postby SP1 » Sun Jul 29, 2018 10:40 pm
Thanks for all your suggestions. I was able to find another mistake on the used kit I bought using these websites. The nut plate to hold the elevator trim screw on the elevator was not installed before the whole part was riveted together. Bummer.
SP1
Postby sonex1374 » Sun Jul 29, 2018 11:57 pm
Sam,
You can use a 3/16 rivet or install a rivnut to hold that clamp. It's not as good as a nutplate on the inside, but may be better than opening it back up again.
Jeff
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Postby SP1 » Fri Aug 03, 2018 12:39 pm
Thanks Jeff for the tip. I definitely did not want to open up the piece for the trim screw.
From the podcast, sounds like you had lots of fun at OshKosh
SP1
Return to Sonex
Users browsing this forum: Bing [Bot] and 11 guests
