3300 fuel flow test
3300 fuel flow test
Postby Rick524 » Tue Jul 17, 2018 5:28 pm
I'm doing a fuel flow test and need advice.
I have the nose raised to 15 degrees. My fuel system is, fuel tank to gascolator to stock Jab fuel pump to stock
Bing carb. I pulled the fuel hose to the carb nipple off and set up the catch bowl under it.
1- How much fuel should drain in 1 min?
2- How much fuel should be in the tank to start the test?
Thanks!
Rick
Sonex 524
Rick524
Re: 3300 fuel flow test
Postby sonex892. » Tue Jul 17, 2018 9:16 pm
You don't use gravity to test fuel flow when the Jabiru mechanical pump is used.
You will need to use the mechanical pump for your test. Spin the motor with the spark plugs removed for a timed period say 10 or 20 seconds then calculate the flow from that. Then the same for the electric pump, if you have one.
Steve
Sonex 892
Steve
Lazair kit 1981 sold
Sonex kit 2010
Sonerai 2LS project rotax 912
sonex892.
Postby Rick524 » Wed Jul 18, 2018 12:13 pm
Thanks Steve.
Rick
Rick524
Return to Jabiru
