builderflyer wrote:Hi Wes,
Good to see you back amongst the Sonex family members. You've been around long enough to remember that the first customer built Sonex to fly (Tony Spicer) utilized cold air induction on his Jabiru 3300. He used an Ellison throttle body because, I believe, the Aerocarb was not yet available. In reviewing his performance numbers utilizing two different props (Sensenich & Prince), when i began testing my airplane, it appeared that his plane didn't perform any better than mine which uses hot air induction with an AeroCarb.
But I've learned to not trust anyone's performance numbers, even mine, and I wish we had more opportunity to test one Sonex side by side with another for reliable bragging rights. Perhaps one or more of the Sonex gatherings could be used for that purpose and put to rest once and for all, who really does have the best performing Sonex out there for any particular airplane category and event.
Wes, as part of your quest for speed (or efficiency), will you be installing Van's pressure recovery wheel pants on your Onex as you did on your Sonex?
Art,,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,,,,,,Jabiru 3300 #261
Straight and level at around 3000 MSL I've seen 165 mph. I'm running too rich right now at over 11 GPH at WOT, so when I adjust the the Aerocarb maybe I'll get more speed.
gammaxy wrote:Wes,
Yours is one of the more interesting threads that has been discussed lately. I'm interested in your experience with cold air induction and totally haven't interpreted anything you've said as offensive and don't think others have either.
SonexFactoryTech wrote:
It is important to remember that comparing airspeeds between airplanes is useless unless all reporting parties have calibrated their airspeed indicators and are quoting True Airspeed (TAS), not indicated airspeed, not ground speed, not what some people call "GPS speed" (which is ground speed). The only accurate comparison method for aircraft speed is True Air Speed and few aircraft owners take the time to calibrate their airspeed indicator to allow accurate TAS calculations. Even if your digital instrument displays TAS it is only accurate if the pitot, static, and outside air temperature sensors are accurate.
The ultimate example of the inaccuracy of indicated airspeed is the Space Shuttle. In orbit, its airspeed indicator would have read zero while the shuttle orbited the earth at 17,320 mph.
Blue Skies....
Kerry Fores
Technical Support Manager
Sonex Aircraft, LLC
builderflyer wrote:Wes,
I didn't do any serious testing after installing the Vans wheel pants but I didn't notice any significant performance increase. What I've told others who want to do the same is "do it for the looks and not for the performance and you won't be disappointed". I spent a considerable amount of time modifying the stock Van's nose wheel pants and adding a cuff to match up with the the gear leg fairings of the Sonex. Sorry for being off topic.
Good to hear from you,
Art,,,,,,,,,,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,,,Jabiru 3300 #261
Users browsing this forum: No registered users and 38 guests
