AN3 Torque ?
Re: AN3 Torque ?
Postby EdW » Wed Jul 11, 2018 10:50 am
Remember, torque wrenches are precision measurement tools, and as such require periodic calibration. In certificated operation, 24 months is limit. How do wrenches get out of tolerance? Usage, dropping, usage, dropping, etc. Like the rest of us, they wear out.
Ed
Onex 209
tailwheel, Aerovee
Nobody here liked the name I selected for my bird, so I am changing it to DILLIGAS.
Just east of Graceland
EdW
Re: AN3 Torque ?
Postby dallen » Wed Jul 11, 2018 11:28 am
Sonerai13 wrote:I use the torque table in AC 43.13 for my AN fasteners.
The torque wrench I have for the small stuff is a Snap-On. I have two actually. One is for really small stuff, 10 to 50 in/lb. The other goes from, I think, 40 to 250 in/lb.
Joe, Could you post "AC 43.13". I would like to see it.
Dave
Onex
dallen
Re: AN3 Torque ?
Postby DCASonex » Wed Jul 11, 2018 12:24 pm
Another place to look for small torque wrenches is gun smith supplies. For AN3 and smaller, I have a small one that looks like a fat screw diver, very good for small places, and quick and easy to use. Be sure to check calibration. If no other known accurate wrench available, use a simple torque arm and weight.
DCASonex
Re: AN3 Torque ?
Postby Bryan Cotton » Wed Jul 11, 2018 2:12 pm
dallen wrote:Joe, Could you post "AC 43.13". I would like to see it.
Dave
Onex
Google can find it for you. You want to download the hardware chapter. It is an FAA document.
Re: AN3 Torque ?
Postby dallen » Thu Jul 12, 2018 11:01 am
Got it thanks.
Dave
dallen
Re: AN3 Torque ?
Postby radfordc » Thu Jul 12, 2018 12:10 pm
DCASonex wrote: Be sure to check calibration. If no other known accurate wrench available, use a simple torque arm and weight.
Here is a video of how I calibrate a torque wrench... https://youtu.be/jdhFqpLJKT8
This was a presentation made at one of the Midwest Sonex Fly-in's several years ago.
radfordc
Re: AN3 Torque ?
Postby Sonerai13 » Fri Jul 13, 2018 10:17 am
http://www.marvgolden.com/downloads/dl/ ... xcerpt.pdf
A web search will find other similar links.
Joe Norris
Sonex N208GD (S/N 450)
Sonerai II N13NN (S/N 1206)
Fortes Fortuna Adiuvat
Sonerai13
Re: AN3 Torque ?
Postby pfhoeycfi » Tue Jul 17, 2018 6:43 pm
DCASonex wrote:Be sure to check calibration. If no other known accurate wrench available, use a simple torque arm and weight.
Thanks for those responses... ended up with a Capri, did the wight x arm test and it was right on...
Thank you,
peter
Peter Hoey
Philadelphia Glider Council
Also built Sonerai IIL N86PH
pfhoeycfi
Return to Sonex
Users browsing this forum: No registered users and 57 guests
