by builderflyer » Thu Jul 05, 2018 9:14 am
Once you have the needle adjusted close to where you want it turn it in a couple of turns and add a drop of blue loctite. Then back the needle up those same couple of turns to engage the loctite. Let the loctite set up before installing the set screw. If you have to make small needle adjustments in the future you can do that and the residual loctite keeps the needle from moving while you engage the set screw once again. Been doing the above for years with success.
Art,,,,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,,,,,Jabiru 3300 #261
