Arnieb wrote:The reason I ask is my RPM"s are running high, Someone told me that perhaps the Propeller may not be too small for engine. The prop is a prince 60" P-Tip.
How high? I used to have a Prince 54 x 60 P-tip and it was too fine for my 3300. Full throttle static was 3000 rpm and at full throttle straight and level it would run to over 3300 rpm. When I measured the pitch at several locations along the propeller blade, the maximum pitch was 59", going down to about 56" in some locations. OK, I'm not an expert on this so you can take my measurements with a big grain of salt, but it did explain the performance.
