by DCASonex » Mon Jul 02, 2018 8:31 am
Robbie,
Just a reminder, with your new Jabiru engine. Do not use the K&N oil filter with on nice hex that is spot welded on end. These look like they should be ideal for our engines, high flow for our thick oil and heavier case for higher pressure However, The pulsations from the Jabiru / CAMit PRV resulted in two of those cracking around the spot welds. one resulting in total oil loss and forced landing airport 5 miles out, fortunately had altitude at the time. Have also had one of the recommended NAPA 1394 Gold filters crack at a small dent, so take care with those. Bob Panther in the UK has been working on a new drop-in PRV replacement that is looking good so far so may have a better option soon. I have tried several alternate designs on my own, but while all got rid of the hydraulic jack hammer effect of the original, was able to find a condition where each buzzed at a higher frequency. Have been too busy with other projects to pursue it further, (or to fly much) -Drat!.
