5 Inch tail wheel assembly questions
Postby n502pd » Sun Mar 24, 2013 6:50 pm
Greetings! My first post! I am scratch building s/n 1510 TD and want to construct the 5 Inch tail wheel, but need to know if there are any drawings for that. Also, what is the recomended part number and source for the actual wheel itself? lastly, any other hints on doing this! Thanks, Joe Nelsen, Gunter, TX :)
Joe Nelsen
scratch built :D
Flying @81.7
KGYI/N. Tx Reg/Perrin Field
n502pd
Re: 5 Inch tail wheel assembly questions
Postby rizzz » Sun Mar 24, 2013 7:12 pm
Hi,
Sonex does not sell any parts to support a 5" tail wheel, however, a member of this forum, Kip Laurie, does.
Kip designed a nice bracket very similar to the sdt Sonex tail wheel bracket, for use with the Vans lightweight 5" tail wheel, all you need is his bracket and the Vans Tail wheel, all other parts remain std Sonex.
Please see this thread:
viewtopic.php?f=21&t=125
rizzz
Postby n502pd » Sun Mar 24, 2013 7:19 pm
Thanks much Michael! The wheel info is what was really needed...which one to get. I have seen Bob Mika's tailwheel and understand how he did the mod. Have you address for Kip?
Joe Nelsen
scratch built :D
Flying @81.7
n502pd
Postby rizzz » Sun Mar 24, 2013 8:00 pm
I would suggest you send Kip a private message on this board, here's a link to his profile: memberlist.php?mode=viewprofile&u=68
rizzz
Postby n502pd » Sun Mar 24, 2013 8:15 pm
Thank you very much! it is appreciated!
Joe Nelsen
scratch built :D
Flying @81.7
n502pd
Return to Sonex
