Burst oil cooler
Burst oil cooler
Postby bvolcko38 » Thu Jun 21, 2018 7:19 pm
First start up today only lasted 10 seconds. My spotter shut me down. Oil cooler sprung a leak. Didn’t even have time to check oil pressure. What could be the cause other than a defective reconditioned oil cooler? Top mount
BV
Bill Volcko XNS0068
Aerovee and Prince P-Tip
V6
First hole 4/1/16
First flight 8/24/18
Phase I complete...finally!!!
bvolcko38
Re: Burst oil cooler
Postby petep » Thu Jun 21, 2018 10:47 pm
Check the rubber mounting rings between the case and oil cooler closely. Easy place to create a leak. If the cooler truly ruptured and was not defective then check your oil pressure plungers to make sure they are not stuck and not relieving the pressure as they should. Sticking plungers is not an totally uncommon issue.
petep
Burst oil cooler
Postby bvolcko38 » Thu Jun 21, 2018 10:55 pm
Cooler was defective or ruptured. Ring gaskets not leaking. Didn’t have time to check oil pressure
Bill Volcko XNS0068
V6
First hole 4/1/16
bvolcko38
Postby NWade » Fri Jun 22, 2018 1:47 am
Bill -
Search for the thread I started, "Oil Cooler Structural Failure". Lots of info there about a similar issue I had.
--Noel
NWade
Burst oil cooler
Postby bvolcko38 » Fri Jun 22, 2018 7:04 am
Thank you much
Bill Volcko XNS0068
V6
First hole 4/1/16
bvolcko38
Postby bvolcko38 » Mon Jun 25, 2018 10:28 am
Bought a good used genuine vw oil cooler. All good now, except...
my oil pressure won't go above 20 psi.
Aerovee, iEFIS D Lite, VDO oil pressure sender
Also rpm reads 7000 at idle.
Much to work out.
BV
Bill Volcko XNS0068
V6
First hole 4/1/16
bvolcko38
Users browsing this forum: No registered users and 63 guests
