Postby Rofomoto » Wed Jun 20, 2018 1:17 pm
Left side quicker. Next up drill deburr and rivet
1735
Longassproject
Rofomoto
Postby Rofomoto » Thu Jun 21, 2018 11:24 am
Left side done now it’s time to make this look like a plane!!!
1735
Longassproject
Rofomoto
Postby Rofomoto » Thu Jun 21, 2018 1:45 pm
Look what happens when you go to fast!!!!!
Slot in wrong spot. Should be towards lower longeron... now what?
Any suggestions ????
1735
Longassproject
Rofomoto
Postby Bryan Cotton » Thu Jun 21, 2018 10:39 pm
I'd patch it and move on.
Postby DCASonex » Fri Jun 22, 2018 8:24 am
Measure twice cut once. Building your own is a learning experience. Should be able to fix that, but keep in mind that the area is one of the most highly stressed on the plane. An excess of added holes for more rivets may only weaken the structure if not carefuly located. Stop and think through where the stresses are and proceed.
David A. Sonex TD
Postby Rofomoto » Fri Jun 22, 2018 10:04 am
DCASonex wrote:Measure twice cut once. Building your own is a learning experience. Should be able to fix that, but keep in mind that the area is one of the most highly stressed on the plane. An excess of added holes for more rivets may only weaken the structure if not carefuly located. Stop and think through where the stresses are and proceed.
David A. Sonex TD
Thanx still figuring that out....
1735
Longassproject
Rofomoto
Postby Rofomoto » Fri Jun 22, 2018 1:02 pm
Screw it! Moving on, I’ll figure it out later lol
1735
Longassproject
Rofomoto
Postby Rick524 » Fri Jun 22, 2018 5:19 pm
Hi Billy, maybe you can incorporate a canopy latch into the extra slot....
or an 'exit' decal to cover it? I'm sure it will work out in the end, don't
worry about it too much.
Rick
Sonex 524
Rick524
Postby Rofomoto » Fri Jun 22, 2018 5:58 pm
Exactly.... I’m over the mess up and back at it
1735
Longassproject
Rofomoto
Postby Rofomoto » Sun Jun 24, 2018 12:07 pm
Waiting on my .032 sheet. Made this. Took way longer than in should have
1735
Longassproject
Rofomoto
Return to Photo Album
