Prop centering
Anything related to props
Prop centering
Postby Kai » Sat Jun 09, 2018 2:08 am
I have been using a Sensenich wood/glass prop on my Jab powered Sonex in combination with the standard massive Sonex supplied spinner since it took to the air in 2005. The only thing that centers the prop on the engine prop flange, are the Jab supplied prop drive lugs, originally with a very snug fit in the prop boss. Every time the prop goes on after the annual, maintenance- whatever, the holes in the prop boss for the drive lugs are getting just a small fraction larger. Finally, after 13 seasons in the air, the hole diameter has increased to such an extent that the prop has become almost impossible to center properly. The result is a peculiar resonance in the airframe, starting around 2800rpm.
Has anybody else experienced this? Is there a cure for it? Comments?
Kai
Sonex #0525 DS-TD
Sonex A #0525- SG, DS.
Kai
Re: Prop centering
Postby peter anson » Mon Jun 11, 2018 12:01 am
Hi Kai, I think it's time to have a chat with Sensenich. The simple solution is a new prop but they may be able to do a repair. An out of balance caused by your prop not being centred is not going to do your engine any good. For those drive holes to wear there must be a problem with either bolt torque or creep in the propeller hub. You could also check that the Jabiru drive bushes have not worn.
peter anson
Re: Prop centering
Postby Kai » Mon Jun 11, 2018 1:47 am
Peter,
Yes- more or less my thoughts as well: I already did contact Sensenich. So far they have been silent.
Kai
Kai
Re: Prop centering
Postby meglin » Fri Mar 17, 2023 9:08 am
I'm sure that's a bad way to center it. The most reliable way is to make an axial insert with a precise fit.
Best regards, Vladimir Meglinsky
My website: http://propeller.mozello.com/
meglin
Return to Propellers
