sonex1374 wrote:xymox wrote:So junk the head now or what?
A new head from Sonex is about $300, and a valve job and new valves will be less than half that cost. Might be worth a try to recondition the head and see how that holds up before deciding to replace it.
Jeff
lutorm wrote:Yeah, I was told when I asked about the crack between the valve seats in our heads is that it's really common and not a cause for concern unless it's actually compromising the seat. That valve and seat looks pretty bad though.
Did you notice the valve clearance needing a lot of adjustment?
xymox wrote:lutorm wrote:Yeah, I was told when I asked about the crack between the valve seats in our heads is that it's really common and not a cause for concern unless it's actually compromising the seat. That valve and seat looks pretty bad though.
yeah they were in need of some .006 pretty bad. I'd say some were about .06. that was causing it to run real bad.
lutorm wrote: If the clearance gets *larger*, I can only think of one think causing that and that would be deposits on the seat causing the valve to remain open, which is also bad.
mike.smith wrote:Carbon deposits have been controlled with proper fuel mixture, but of course that's a bit of a moving target in the AeroVee since the front and rear cylinders get demonstratively different fuel mixtures.
Users browsing this forum: No registered users and 82 guests
