sonex1374 wrote:Looking at the photo of the valves, the coloration on the exhaust valve is a bit uneven, and it looks like the valve seat may have changed position slightly. If the clearance on the rocker arm adjuster has opened up, that might suggest the valve seat has shifted. It might be time to send the head off to a bug shop for a valve job, including a new guide and seat on the exhaust valve. Might not be anything to worry about, but worth investigating perhaps.
Jeff
xymox wrote:I disagree in part. The most probable scenario is reusing the same plugs and over torqing and using the same crush washer and the auto lite plugs. Results = too much penetration.
xymox wrote:After I ' looked a bit more' I realized that it was in fact making contact with the piston head. See attached picture. So now the question is, why would the clearances move enough to cause interference after over 150 hours?
xymox wrote:So junk the head now or what?
