Onex107 wrote:There are two places that could allow that to happen. The shims on the cylinder barrel and the thickness of the fire ring. Have you re-torqued the head and seen a lot of change? New heads with new fire rings? They come in different thicknesses. Did you use silicone to seal the cylinder shims? Physically the compression ratio had to change to allow that to happen.
Users browsing this forum: No registered users and 54 guests
