Plugs bent over and engine running rough and hot.
Postby xymox » Fri May 25, 2018 10:06 pm
Wierd situation happening. Engine started running hot so did the usual adjustments to the needle and noticed no real difference. Decided to reinstall the stainess needle and still ran like crap. Noticed number 4 egt was running real hot on climb out 1450s but under idle it was cooler than the number 3 egt. Both egts are in the rear by the way.
Was doing some static wot pulls to see if I could reach the normal 3200 rpm I would expect... Bogged down at 2800 ish and could hear what sounds like detonation and backfiring.
Finally pulled valve covers and noticed valve clearanse was way off( sloppy) so tightened them all down to .006 per the manual. Also pulled plugs and noticed number 2 and 3 bottom plugs we're bent over so that ground strap was touching electrode. Put new plugs in and Ran engine and was running fine after some high speed taxis. Pulled bottom plugs again and the same 2 and 3 we're bent over. Regaped and added an extra crush washer to the problem plugs. Still runs fine.
Pulled head and jugs... Noticed some lead buildup which I scraped off but sure wasn't thick enough to cause any interference. No lateral play in the piston and connecting rods. Top of Pistons showed no signs of impact with anything . Kind of at a loss as to what would cause the plugs to fold over.
xymox
Re: Plugs bent over and engine running rough and hot.
Postby xymox » Fri May 25, 2018 10:53 pm
After I ' looked a bit more' I realized that it was in fact making contact with the piston head. See attached picture. So now the question is, why would the clearances move enough to cause interference after over 150 hours?
xymox
Postby Brett » Fri May 25, 2018 11:00 pm
MoFoCo heads I assume?
Sonex 1645
VH-VWS
Tailwheel
Former Aerovee Turbo
Rotax 912
Brett
Postby xymox » Sat May 26, 2018 10:12 am
Sure are. I guess it's luck of the draw.
Anyone know of a shorter plugs that can be used?
xymox
Postby Onex107 » Sat May 26, 2018 11:32 am
There are two places that could allow that to happen. The shims on the cylinder barrel and the thickness of the fire ring. Have you re-torqued the head and seen a lot of change? New heads with new fire rings? They come in different thicknesses. Did you use silicone to seal the cylinder shims? Physically the compression ratio had to change to allow that to happen.
Postby Onex107 » Sat May 26, 2018 11:36 am
I have been know to put a head back on and did not know the fire ring had dropped out until I found one left over.
Postby Brett » Sat May 26, 2018 1:47 pm
I use the NGK plugs DR8EA, they are just shorter than the Autolite ones and have clearance in my circumstance.
Sonex 1645
VH-VWS
Tailwheel
Rotax 912
Brett
Postby xymox » Sat May 26, 2018 2:55 pm
That's exactly the plugs I picked up this morning. Thanks!
xymox
Postby sonex1374 » Sat May 26, 2018 3:01 pm
Looking at the photo of the valves, the coloration on the exhaust valve is a bit uneven, and it looks like the valve seat may have changed position slightly. If the clearance on the rocker arm adjuster has opened up, that might suggest the valve seat has shifted. It might be time to send the head off to a bug shop for a valve job, including a new guide and seat on the exhaust valve. Might not be anything to worry about, but worth investigating perhaps.
Jeff
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Postby xymox » Sat May 26, 2018 3:15 pm
Onex107 wrote:There are two places that could allow that to happen. The shims on the cylinder barrel and the thickness of the fire ring. Have you re-torqued the head and seen a lot of change? New heads with new fire rings? They come in different thicknesses. Did you use silicone to seal the cylinder shims? Physically the compression ratio had to change to allow that to happen.
I disagree in part. The most probable scenario is reusing the same plugs and over torqing and using the same crush washer and the auto lite plugs. Results = too much penetration.
xymox
Users browsing this forum: No registered users and 67 guests
