by robin » Fri May 25, 2018 10:24 am
My #3 cylinder is missing on my secondary ignition. On the ground at 2000 rpm, mags only will show about 20 rpm drop, secondary only will show 200 to 300 rpm drop, vibration starts, sounds like a missing cylinder and #3 cylinder EGT drops rapidly. Engine starts instantly.
Initially the problem was intermittent in that on some flights no issue and on others every test of the secondary produced the miss.
My remedy attempts were as follows:
My first suspect was a coil as I have had to replace both previously. I bought a new coil and swapped out each coil. No difference.
Tested each spark plug for spark. All OK.
Replaced #3 spark plug. No difference.
Bought a new trigger unit and replaced the bottom trigger feeding #3. No difference.
Replaced the entire plug wire on #3. No difference.
I’m out of ideas. Any suggestions?
Robin
Sonex.
