Brett wrote:I've tried the air ducts facing that way. I've turned mine around now so they face forward in the hope the air flow is directed onto the radiator. I have no way to test wich direction is better but I have no plans to swap them around again.
Rynoth wrote:This is the direction I'm currently headed with my Turbo cooling solution.
This picture shows in the top right the smaller radiator I plan to use, with the plans radiator in the top left. The rest of the components in this photo are from the sonex suggested parts:
http://www.rynoth.com/wordpress/wp-cont ... _1893.jpeg
This photo shows the suggested fan on my radiator (not yet fastened), next to the suggested radiator. I do not plan to build a duct between fan and radiator. I will use long screws or bolts to attach the fan to the heat exchanger directly through the fins, avoiding puncture of the fluid channels.
http://www.rynoth.com/wordpress/wp-cont ... _1894.jpeg
I was struggling and failing to find a place to mount such a large radiator as suggested by the Sonex plans in my legacy Turbo installation, which is why I looked for a smaller heat exchanger.
Below are 2 pics of 3" circular aluminum ducts I bought from Amazon, before and after painting.
http://www.rynoth.com/wordpress/wp-cont ... _1843.jpeg
http://www.rynoth.com/wordpress/wp-cont ... _1880.jpeg
n307tw wrote:
Hey do you mind posting a link to where you can buy the radiator you chose? I think it is a much better option than what Sonex suggests. Also where are you mounting the coolant pump? Thanks in advance for the help/suggestions.
-Tim
I am wondering if the Turbo is now a viable option...
Users browsing this forum: Google Adsense [Bot] and 97 guests
