New Builder
Re: New Builder
Postby lstinthot » Fri Mar 15, 2013 4:20 pm
Welcome to the club. I too am a recent purchaser of plans. I am using www.sonex1604.wordpress.com to publish my build online. It is a free blog site and easy to use with a smartphone. I am also using the spreadsheets from the yahootalk site to track the build of each part and help with which parts to build based on material I have. I did not order all the material at once. Bought most of the material to build the tail. If the tail needed a 2.5 x 2.5 x3/16" angle I bought all the angle for the plane. The only metal I have not bought so far to finish the tail is the 0.025" sheet, and that is because I can not get it locally and will have to order it online.
Are you scratch building or waiting on a kit to arrive?
Best of luck
Mike Nichols
Scratching #1604
Scratch building #1604
Tail dragger
Thinking Turbo Aerovee
lstinthot
New Builder
Postby sonex 1614 » Fri Mar 15, 2013 8:27 pm
I am liking the spreadsheets and the web pages, I may do both like some of you did. I appreciate all of the insight. I will be building using the sub kits. I bought the plans so I could study them before I started cutting into expensive metal. I also knew I wanted to go to the workshop, so I figured it wouldn't hurt to get familiar with the plans before going up to Oshkosh.
Tony
Sonex 1614
Chicago Area
sonex 1614
New Builder
Postby Sonex1517 » Fri Mar 15, 2013 8:36 pm
I think I know where you can find some scrap pieces to practice with. :)
Robbie
Sent from my iPad using Tapatalk HD
New Builder
Postby sonex 1614 » Fri Mar 15, 2013 9:09 pm
Nice! Never hurts to practice.
Tony
Sonex 1614
Chicago Area
sonex 1614
New Builder
Postby sonex 1614 » Fri Mar 15, 2013 9:15 pm
fastj22 wrote:
sonex 1614 wrote:Thanks for all of the responses. I have some time after work today to have a cup of coffee and lay the plans out to take another look. Once more question... Any suggestions on which online build log to use? Is anyone using a different online source to log their build?
Thanks in advance!
Check out this excel spread sheet.
I found it on Sonex Talk. The author did a great job detailing each step on each page. Just put in the time you spent on each step. I passed my DAR inspection with it. Haven't gone before the FAA go get my repairman's certificate yet, but I hope it will be sufficient to prove I built the plane.
http://f1.grp.yahoofs.com/v1/mGpCUWx7ss ... %20Log.xls
Can you resend is link, it didn't work for me.
Tony
Sonex 1614
Chicago Area
sonex 1614
Re: New Builder
Postby fastj22 » Fri Mar 15, 2013 9:22 pm
sonex 1614 wrote:
Thanks in advance!
Go to the yahoo sonex talk yahoo forum and click files. It's called no298 builders log.
New Builder
Postby sonex 1614 » Fri Mar 15, 2013 9:33 pm
Found it! Thanks.
Tony
Sonex 1614
Chicago Area
sonex 1614
Re: New Builder
Postby sonex 1614 » Thu Mar 21, 2013 1:04 pm
I am in the process of collecting tools for the build. I have managed to scrape together a good amount of used tools that Sonex recommends. Are there any invaluable tools anyone might suggest? I am planning on buying my tail kit in June, so I have plenty of time, just curious.
Thanks!
Tony
Sonex 1614
Chicago Area
sonex 1614
New Builder
Postby Sonex1517 » Thu Mar 21, 2013 1:13 pm
Strap duplicators. But you knew I'd say that....
Robbie
Re: New Builder
Postby EricS » Thu Mar 21, 2013 1:24 pm
I just recently bought a 90 angle drill motor. I ran into several places on the fuselage where my palm drill wouldn't fit. You can get angle drill adapters for a palm drill if you don't want to buy a separate drill motor. The angle drills are fairly expensive, but have saved me a lot of hassle. Here's a link to the kit I bought from Northern Tool : http://www.northerntool.com/shop/tools/ ... _200451730
Eric Seber
Waiex #153
Jasper, Indiana
http://www.mykitlog.com/EricS/
EricS
Users browsing this forum: No registered users and 57 guests
