Hi All,
I recently assembled my AeroConversions AeroBrakes onto my Sonex axles, and noticed issues with my installation. Others have posted messages about the AeroBrakes in the past, but I wanted to consolidate their learnings and incorporate the info I've recently received from Sonex/AeroConversions - making it easier for folks to find this info in the future.
As several people have commented, the AeroBrakes are clever, compact, and a good design; but the instructions leave something to be desired. :roll: And as I found out,
parts changes in the Sonex lineup over the years can have an effect on how your AeroBrakes go together onto your Sonex aircraft. Hopefully the list below provides a series of answers and items to check when assembling your wheels & brakes...
- The clevis pins called out in the plans are incorrect. They should be "-3C39" length pins for standard Sonex/Waiex axles.
[Source: My emails with Sonex/AeroConversions Tech Support]
- Clevis pins are preferred over the bolts listed in some plans/instructions sheets because bolt-heads can stick out further and possibly contact wheel components.
[Source: Sonex plans revisions, see SNX-L07 revision posted on 4-1-13]
- The Brake Pistons are installed with the narrow part of the piston facing down into the brake housing, and the O-Ring nearest the top of the piston.
[Source: Shown on SNX-L07 Detail B but it is very hard to see. You can download the PDF from Sonex and zoom in to view this much better than is shown on the printed version.]
- Check your bearings when you assemble the brakes and wheels onto the axle! The axle nut should be turned until the brake pucks are lightly dragging on the brake disc. Then be sure to examine both sides of the wheel, paying attention to the wheel bearing area. On the outside of the wheel, the nut should be contacting the bearing washer. On the inside of the wheel the raised lip of the brake housing (where the axle slides through) should be contacting the bearing washer. NOTE that Sonex changed the Azusa tapered roller bearings over the years. Both wheel bearings will work, but the older (unsealed) wheel bearings are not as wide. This may leave a gap between your brake housing and the wheel bearing, and might allow the bearing to move and the wheel to be improperly supported as the brake pucks wear down. Here is a photo of this issue. Sonex support suggested two solutions to my particular issue: You can stack up washers between the wheel bearing and the brake housing, or you can order the newer sealed Azusa bearings, which are thicker and will take up this space. To order the bearings, Log In to the Sonex Web Store and then do a search for "Azusa-8229" (and yes, you must log in first). They are sold as individual items not pairs, so you'll want to order 2 or 4 of these.
[Source: Emails with AeroConversions/Sonex Tech Support]
I hope this information is helpful, and everyone gets good use and long life out of their AeroBrakes!
--Noel
