Bryan Cotton wrote:That also accrues fatigue damage but at a low rate for normal flying. Metal does not care if it carries a load for a millisecond or a millennium. It is the cycles which matter.
Bryan - I agree with your philosophy here, but I think you have over-simplified it slightly, and left out an crucial part of the equation for everyone playing along at home. If I'm not mistaken, fatigue life is limited by the result of cumulative damage from load cycles as you suggest, however, we cannot overlook the importance of the amount of damage caused by each cycle which varies due to input loads. "Duty-cycle" is the term I'm familiar with...
A 6 G load accumulates more damage than many, many, many more 2 G loads, right? I think that is why Mr. Anson reminded us of the log scale, and that it is a S/N 'curve' and not S/N 'line', since fatigue loading is not a linear relationship.
In context, a generic 9 G 'rating' (likely just shy of the actual over-load condition) I believe really describes a single event (cycle), correct?
I don't mean to take away from your contribution and explanation of fatigue for the subscribers, but I'd like to help expand understanding as well, so somebody tell me if I'm wrong.
Here's my main point:
Perhaps most importantly, we all should consider that these rating type tests are typically performed with a single data point (think manufacturer/designer expense here - how many times do you need to prove you pass a test since each test destroys the part?). Our mileage (or in this case, expected rated aerobatic "capacity") will vary depending upon our skill levels, and how close to exactly duplicating the original test assembly we can achieve as we build. Part variations due to manufacturing and assembly tolerances tend to wreck all our statistical information on fatigue failure analyses. As Mr. Anson suggests, the curve he provided represents 'typical' aluminum. These curves comes from a group of material 'coupons' tested (to failure) to get a statistical representation of that material. Confidence in the known fatigue life goes down as assembly complexity increases (beyond the homogeneous coupon). That fact has disturbed me no-end as I read through the engine durability comparison / justification threads. Apples and potatoes... we need to be aware of the complexities of the data presented in forums like these.
