MichaelFarley56 wrote:One more item to consider Noel; are you sure your manifold pressure gauge is calibrated properly? Did you calibrate it per the MGL manual?
If you’re getting good engine rpms (which it sure seems like you are) then there’s a good case here you’re getting the manifold pressure you need. If you’re only pulling 35” or so, I’d guess your rpms would not be quite that high unless you have a climb prop installed (what prop do you have?)
On my engine, I could easily get 40”+ on the ground before the throttle was even pushed in all the way. Remember there’s a bit of a lag on the turbo and it takes a little bit of time for everything to stabilize. If I was being smooth on my throttle, either during a ground run or on the takeoff roll, I’d push the throttle up until it hit around 35” and by the time it stabilized, I’d be around 38-40” or so.
Your idea of checking of intake leaks is also a good one, but if it’s running smoothly I’d start by checking the gauge to make sure it’s accurate. Or find a mechanical gauge and temporarily attach it just to check for the accuracy of the MGL.
Good luck!
wlarson861 wrote:Whenever I had low boost (35 in map) it was always the piston bearing. Sometimes the drag on the turbine wheel was barely perceptible. Doing the solvent soak once did fix the problem for a while. You may want to try the soak before anything more aggressive.
XenosN42 wrote:Question for you. Have you recorded any of your engine runs using the MGL 'Black Box' functionality? If so can you send me a copy of the 'iEFIS.rec' data file which you'll find on the SD card? I'm writing an application that shows the recorded data in a user friendly manner. To this point I don't have a sample file containing MAP data.
Users browsing this forum: autopro and 61 guests
