SNX-F26 -01 02 -03
SNX-F26 -01 02 -03
Postby Rofomoto » Tue Apr 03, 2018 7:42 pm
on F-26 i have cut -01 R and -02R to proper lengths..but with the 3/4" set back on the front for the 14 deg bend the rear longerons cover the last row of rivet holes a little..my skin measures 2809mm long and upper longeron measures 2786mm do i cut back longerons?
1735
Longassproject
Rofomoto
Re: SNX-F26 -01 02 -03
Postby Rick524 » Tue Apr 03, 2018 10:29 pm
Hope I understand your question.... the longeron mounts on the skin starting from the bend line.
It runs to the rear of the skin and stops about 1" from the end of the skin. Your lengths of 2786
and 2809 are correct.
Hope this helps.
Rick
Sonex 524
Rick524
Postby Rofomoto » Wed Apr 04, 2018 10:56 am
i have doubled and triple checked my measurements..when you subtract the two measurements you come up with 23mm difference. if you subtract 19mm from 23mm (the amount to set back of the 19mm for the 14deg bend)your only left with 4mm. the last set of rivet holes are 6.3mm from the end of skin thuss covering holes.. thanx for any help Billy
1735
Longassproject
Rofomoto
Postby Rofomoto » Wed Apr 04, 2018 11:54 am
just figured it out... 2809mm didn't include the 19 mm bend measurement guess im making new sides... i'm an idot again!!!
1735
Longassproject
Rofomoto
Postby Rick524 » Wed Apr 04, 2018 1:57 pm
You're not the first to make a mistake, nor the last. Move on
and keep building.
Rick
Sonex 524
Rick524
Postby daleandee » Wed Apr 04, 2018 2:35 pm
Rick524 wrote:You're not the first to make a mistake, nor the last. Move on
and keep building.
Yep ... I would only add to keep all the parts you screw up as many times they can be used to make other stuff later ...
Dale Williams
N319WF @ 6J2
Myunn - "daughter of Cleanex"
120 HP - 3.0 Corvair
Tail Wheel - Center Stick
172.6 hours / Status - Flying
Postby Bryan Cotton » Wed Apr 04, 2018 3:29 pm
Anybody can do it right the first time. It takes real skill to fix a screw up.
Postby kmacht » Thu Apr 05, 2018 9:47 am
I did something similar. I thought I was being smart when laying out my fusealage skins. I used the 1” mark on the ruler instead of the end thinking it would make for a more accurate measurement. Unfortunately I still marked and cut the skins at the plans length making them 1” too short. I didn’t realize it until I started riveting things together. I honestly thought about shortening the whole airplane by 1” but ultimately just made new skins and turned the scrap ones into wing ribs. This won’t be your last mistake. The nice thing is that they are all recoverable with time and a little material.
#554
Postby Rofomoto » Thu Apr 05, 2018 10:35 am
lol thanx for the support!!! billy
1735
Longassproject
Rofomoto
Postby daleandee » Thu Apr 05, 2018 10:51 am
kmacht wrote:I did something similar.... This won’t be your last mistake. The nice thing is that they are all recoverable with time and a little material.
I bought a couple of extra parts along the way (still have a spare elevator on a shelf in the hangar). Bad measurements happen to the best. Here's one that was caught in time:
http://websites.expercraft.com/daleandee/index.php?q=log_entry&log_id=47397
I had days when I left the hangar feeling elated ... and many when my belly was full of humble pie.
Dale Williams
N319WF @ 6J2
Return to Sonex Plans
