pschwenn wrote:Passes Rich/Lean test - tho I can't do it fully because I can't quite reach WOT.
pschwenn wrote:(after richening by a third needle turn clockwise since my post)
pschwenn wrote:Responder,
Thanks very much
I only have two EGT sensors. I will swap them, then move them fore'n'aft. I've ordered one in case one is defective.
I just tried occluding oil radiator cowl entry by half - seemed to help - previously oil temp might get to 175f after forever.
Next I'll richen a bit more. And then try a 2.5 needle.
Pushing mixture rich always lowers EGT and and RPM,. And vice versa. Closest I've come to a full WOT rich/lean test is (after richening by a third needle turn clockwise since my post) at 2800 rpm, pushing from opt lean all the way in lowers EGT by 70f.
I'm going to judge in future more by plugs, which I'm very familiar with, ability to reach smooth WOT, and idle. (But making sure initially that my EGTs are neither defective nor way out of line.)
I'm still digesting these very useful replies.
Thanks again
sonex1374 wrote:Peter,
A few things stood out in your initial post.
1) Oil temp is slow to come up. What temp does it reach at maximum (sustained climb), and what is a typical cruise oil temp? I think you may be over-cooling your oil. If you have a bottom mount oil cooler, you may need to reduce the size of your air inlet to the cooler. If you have a top mount, try blocking off some of the cooler surface.
2) If your plugs are light brown, you may be running too lean at full throttle. Using an aerocarb/aeroinjector and tuned for a good, rich-enough mixture at WOT, it is very common to need to lean aggressive at low throttle to keep the mixture lean (and the plugs tan-to-brown in color). If you don't lean at idle, your plugs will almost certainly be black after even a few minutes. So here's the question: are you leaning aggressive at idle and getting tan plugs, or are you only leaning a little and getting tan plugs? On your new engine I'd expect to hear that your plugs are black but WOT runs well, rather than your plugs are tan, and the engine runs hot.
3) Idle at 950 is typical of a new engine. It will be possible to idle lower once broken in, but probably not below 800. If you set it too low early on, the engine may die on short final as you pull the power all the way back.
4) Needing to pull the mixture knob almost all the way out at idle is typical. This doesn't really tell you much about the tuning of the carb. A well-tuned carb will still allow you to lean aggressively at idle, just as a very-lean tuned carb will.
Regarding your testing plan, I have a few thoughts as well.
1) You can check the EGT sensors with a candle, but it's hard to really calibrate them. You can learn more by swapping probes in your exhaust pipes. It's a pain, but if you really want to determine if it's a probe problem or a EGT problem, swapping probes around and comparing the temps registered by different probes will tell the tale.
2) You can check for leaks by spraying down the joints on your intake system with carb cleaner or starting fluid. If there's a leak, the intake will ingest the fluid and change the way it runs. You'll know it.
3) Making the exhaust deflector lips larger won't help as much as simply increasing the size of the exits. Really small lips are a problem, but the stock ones are fine.
4) Switch to a bigger needle. This is my suggestion as well. Install a 2.5 and tune for a good, rich WOT mixture. It's OK to even need to lean a touch at WOT to run smoothly. Don't go crazy, but do ensure you're getting enough fuel at WOT. Don't be afraid to lean it a bit on climb out - if you are running a bit rough and it smooths out with a little leaning, then you were a bit on the rich side and have now confirmed that. An added bonus of the 2.5 needle is that once you get the WOT mixture tuned, the mid-range and idle will both be leaner, and you'll need less leaning at low power than with the 2.0 needle.
Jeff
Users browsing this forum: SNX1508 and 38 guests
