kevinh wrote:The reason I ask is won't the whole airbox assembly be vibrating wrt the engine, so safetying to the engine mount might be working against you.
Rynoth wrote:I did something similar to what Noel did but used a 3-4" x 1/2" wide strip of aluminum sheet with a tab bent at both ends. I fixed one end to the top of one of the air filter bolts, and the other end to an adel clamp on the engine mount. The end result is fairly flexible and shouldn't impart too much in terms of vibration, but does maintain a positive force to keep all the intake connections intact.
Users browsing this forum: Capt T and 17 guests
