Fuel level checks
Re: Fuel level checks
Postby Corby202 » Thu Mar 08, 2018 5:10 pm
I use a dip stick made from a length of plastic tubing and a piece of welding rod inside it to keep it straight. This I calibrated with the tail down and just insert it through the filler neck before each flight keeping a finger over the end to see where the fuel level is.
I also have a fuel gauge also a backlit camera but I find the camera hard to read on a sunny day.
Did have a red cube fuel flow also but could never get that to work properly.
Phil Bird
Sonex 759 JAB 2.2 Tailwheel
Mittagong NSW Australia
Corby202
Postby dtwolcott » Thu Mar 08, 2018 5:21 pm
I also plan on using the backup camera method. I have not wired it in yet. I expect it will provide a little more comfort in knowing how close to empty the tank actually is when it is getting closer to the time for a refill. Always nice to have some sort of visual reference. Similar to flying VFR as apposed to IFR.
Don
Don
Waiex 132 N132YX
3MY
dtwolcott
Postby mike.smith » Fri Mar 09, 2018 2:05 am
Bryan Cotton wrote:The plastic tube full of fuel in the cockpit makes me nervous. I worry about how it will age. If not for that I agree that is the best way.
4 years and no issues. You MUST use clear FUEL tubing, and nothing else! There have been thousands of aircraft flying for decades with exposed fuel sight gauges. Not really a big deal.
Postby SNX1508 » Fri Mar 09, 2018 7:07 am
There is tubing made specifically for this type of application. It is UV, Fuel, and Alcohol resistant. You don't use just any clear tube from the hardware store. I don't have a link handy so hopefully someone on here can point you to it. ...........
#554
I have been using Superthane® Ether Base Tubing for all fuel lines on my Pegasus powered parachute since 2007 with no problems, other than the inside of the tubing becomes discolored after a couple of years, at which time I replace it.
From the US Plastics website:
•Resistant to oils, greases & fuels
•Plasticizer & phthalate-free
•Available in ester & ether formulations
•Transparent, flexible, resilient & tough
•Tear, impact, radiation & abrasion resistant
•Durometer hardness (shore A): 85 +/-5
•Temperature range: -85°F to 175°F
•Meets FDA standards
•Ether based is NSF 61 listed, UV and weather resistant
Here is a link
https://www.usplastic.com/catalog/item. ... emid=83856
Terry L. Cooper
SNX #1508
Tail Wheel
AeroVee #0736
N296SX
2005 construction hours, and was completed in October 2016
First engine run: https://www.youtube.com/watch?v=K9wP77I ... e=youtu.be
FAA Inspected & Airworthiness Certificate issued 11/4/2016
Sport ASEL endorsement on 8/9/2017
Tailwheel endorsement on 9/7/2017
Sonex #1508 N296SX first flight on 11/29/2017
Terry
Sonex #1508
N296SX
AeroVee #0736
Tail Dragger
SNX1508
Postby Bryan Cotton » Fri Mar 09, 2018 7:18 am
I always thought the PA18 sight gauges were glass. That is the one type I've flown with them, that I can remember.
Users browsing this forum: No registered users and 48 guests
