kmacht wrote:John,
I’m just starting my corvair conversion so I can’t give final weights but can say that my airplane with the aerovee weighs 667lbs empty. I normally fly solo and do not do aerobatics. I expect the corvair to add around 60 lbs to that and also expect to have to move the battery aft to ensure CG stays within limits. I will post the post conversion weights and all the CG calculations to this forum once done. As far as justification, I’ll provide you my justification for why I feel safer flying behind the heavier corvair as soon as you provide your justification as to why we should still be comfortable flying behind an engine in which the factory has crashed two aircraft with and still has no idea as to why.
#554
kmacht wrote: I’ll provide you my justification for why I feel safer flying behind the heavier corvair as soon as you provide your justification as to why we should still be comfortable flying behind an engine in which the factory has crashed two aircraft with and still has no idea as to why.
#554
