AeroVee oil analysis
Postby tom0nex74 » Sun Mar 04, 2018 5:22 pm
Fellow members; First few oil changes on 0nex 74 showed lots of Aluminum flakes in the cut open filter. At 100 hrs I began oil analysis which showed high Copper, aluminum and iron. I am at 220 hrs now and these values have not changed. The engine is running well, developing good power, has good compression. Oil color seems normal to me. (Valvoline racing oil ,aviation fuel) Has anyone had similar experiences?
Is there a problem? I,m flying along on the "If it ain't broke, don't fix it" mode now. Would appreciate any in-put.
Installed the AirWard anti burp system in 2014, haven,t had a problem since.......................Tom Ryan onex 74
tom0nex74
Re: AeroVee oil analysis
Postby mike.smith » Mon Mar 05, 2018 12:38 am
You don't happen to have the Nickasil cylinders, do you?
Postby tom0nex74 » Tue Mar 06, 2018 1:58 am
Mike
0nex 74 has standard steel cylinders
tom0nex74
Postby lutorm » Tue Mar 06, 2018 7:12 am
The only place I can think of where aluminum is a wear surface is the lifter bores, although I guess the main bearing shells are made of aluminum these days, too. Copper is part of Babbit, right? That seems like bearing material, too.
lutorm
Postby kmacht » Tue Mar 06, 2018 9:38 am
How is your crankshaft endplay? Any significant movement if you try to push and pull the prop back and forth? How about compression and oil consumption? When you say the values are high, what are the actual percentages?
#554
Postby wlarson861 » Wed Mar 07, 2018 12:42 am
take a look inside the oil pump to check the cover and area behind the gears. Both have steel against aluminum. Possible source for aluminum and easy to eliminate as cause.
Bill Larson
N861SX
wlarson861
Postby mike.smith » Wed Mar 07, 2018 6:41 pm
tom0nex74 wrote:Fellow members; First few oil changes on 0nex 74 showed lots of Aluminum flakes in the cut open filter. At 100 hrs I began oil analysis which showed high Copper, aluminum and iron. I am at 220 hrs now and these values have not changed. The engine is running well, developing good power, has good compression. Oil color seems normal to me. (Valvoline racing oil ,aviation fuel) Has anyone had similar experiences?
VW engines were not designed to have a paper filter; only a screen, so you may be seeing things that are in other engines, but just not seen (just spitballing here). Have you run this by the factory? They may be of more help with the analysis than us random guys on the Forum.
Postby Spinnetti » Wed Mar 07, 2018 8:22 pm
check out www.bobistheoilguy.com You can send in your oil for analysis and the website is good with lots of people interacting
Spinnetti
