radfordc wrote:..
I think the root cause is proven...it's bubbles in the fuel caused by hot gas vaporizing in the fuel line. When these bubbles reach the Aerocarb you get a "burp". This happens most often with Mogas and especially when running "winter blend" that has a lower vapor pressure.
mcjon77 wrote:That is what I remember too. IIRC, the "burping" issue wasn't limited to Aerovees. Jabirus that were using the Aerocarb instead of the standard bing carb also had that issue ...
daleandee wrote:
You are quite correct. The problem with burps isn't the engine it's the Aerocarb. But I believe this "burping" issue is serious enough that every new builder that intends to use an Aerocarb should be made aware of it.
mike.smith wrote:AeroVee and AeroInjector. No gas collator. Fire sleeve and one other layer of plumbing pipe insulation, held in place with reflective heat tape. Not a single burp in 3 years and 270 hours.
ScottM-Sonex1629 wrote:Do those of you trashing the AeroVee realize what you are doing to the reputation and resale “value” of the engine and our aircraft?
ScottM-Sonex1629 wrote:mike.smith wrote:
Do those of you trashing the AeroVee realize what you are doing to the reputation and resale “value” of the engine and our aircraft? I’m tired of reading about the generalizations of a few on the entire fleet of AeroVee’s. It’s a public forum and it’s hurting the brand and the engine.
radfordc wrote:Once I insulated all the fuel lines and the gascolator with firesleeve, foam pipe insulation, and aluminum reflective tape I never had another problem with burps, even with Mogas.
