Marrahm wrote:Anyone have data on change in stall speed with sport mod and shorter flaps? Or recommendations generally on the sport aileron modification? As a new pilot starting on my wing build this week, I suspect i dont *need* more sport in my new toy, but if there really is no material increase in stall speed, it seems like a fair trade.
This report is the only one i’ve been able to find so far and it does not have any numbers other than “a few knots” on stall changes. http://www.sonexaircraft.com/aircraft/sa_test.html
Mike, 1713B
Fastcapy wrote:Mine has the sport ailerons and I have flown 3 others without. I really do not notice the difference other than the larger ailerons require more force for full deflection.
I honestly don't feel like they are "aerobatic ailerons" because I feel they don't increase the roll rate substantially, at least not enough to call them acro ailerons. I actually find them cumbersome for acro due to their large chord... I have thought about trying to add spades but decided it isn't worth the effort.
Slow speed aileron authority is where I feel they shine.
Even with the shortened flaps the stall speeds are still low. With mine I see VS0 stall speeds around 41mph at gross.
fastj22 wrote:The barn door flaps of the standard are way to big and I doubt you'd ever use full flaps that much. Most guys I know with them only use 20 degrees unless going into something really tight.
Users browsing this forum: No registered users and 43 guests
