I suggest that you don't pick apart the research/development Sonex is doing before it's complete. In order to do good development work you change one thing at a time and test and document the results. This takes a lot of time. Be patient. They haven't been able to test in 90 degree ambient temps. yet. It's cold in Wisc. I don't expect any postive conclusions until 2018 Oshkosh.rizzz wrote:One comment, one concern.
Start with the comment:
For those who claim other companies make you pay for SB services and parts, that’s not always the case. I know this for a fact.
My hangar buddy is completing his RV-7A project. He’s got a brand new Lycoming engine that has not run yet.
Perhaps some of you might have heard of a recent Lycoming mandatory SB affecting a certain batch of engines, if I remember correctly it had something to do with the wrong bushings having been used on the conrods ?
Anyway, the engines affected required partial disassembly, inspection and perhaps replacement parts if they are found to be faulty.
My hangar buddy's engine was one of those and since he bought his Lycoming through Vans and they will be paying for this, but I’m sure they will in their turn claim back their cost from Lycoming.
Anyway, it might depend on the circumstances but here’s at least one example I know for a fact where the supplier pays for services and replacement parts caused by a mistake on their part.
Now more importantly, one major concern I have with the proposed solution:
That electric fan. Those things are very sensitive to moisture and they do short out when exposed.
I know this from experience because I was a Bitcoin miner and owned an Antiminer S9 up until a month ago or so when I sold it.
If you don’t know what an Antminer looks like, just google it. You’ll notice they have 2 very similar 4.5” fans on the front and back of these units, 6000rpm on the front and 4500rpm on the back (they produce a lot of heat so require serious cooling).
Anyway, my miner was set up in the garage and because of the heat and noise these things produce. I had my miner draw air from the outside through air conditioning ducting which I had running uphill and I also had a filter in the system to minimize moisture.
Still, in the space of a couple of months I’ve had to replace the front fan of the miner twice because moisture had crept into the centre coils/electronics and shorted out the thing. This would happen after a foggy or rainy day so I stopped running the miner on those days.
Now we know the Sonex cowl is not weatherproof, at least not my older vertical split version, so, to ensure this time things do not happen “outside the scope of testing”, can I suggest you fly the test aircraft sufficiently through foggy and rainy conditions and see what effect it has on this fan?
After all this, the one thing you would not want to happen is have your customers stuck with a solution where they have to replace the fans of these units every couple of months.
Onex107 wrote:I suggest that you don't pick apart the research/development Sonex is doing before it's complete. In order to do good development work you change one thing at a time and test and document the results. This takes a lot of time. Be patient. They haven't been able to test in 90 degree ambient temps. yet. It's cold in Wisc. I don't expect any postive conclusions until 2018 Oshkosh.rizzz wrote:One comment, one concern.
John Monnett wrote:What? "Test fly in foggy and rainy conditions"... are you serious? This has nothing to do with the condition of flight only the post shutdown heat soaking of the turbo and coking!
John Monnett wrote:If a fan would fail on the ground so what?
rizzz wrote:After all this, the one thing you would not want to happen is have your customers stuck with a solution where they have to replace the fans of these units every couple of months.
