by fastj22 » Mon Feb 05, 2018 9:48 pm
My vent line is an Autozone brake line with the ⅛ NPT fitting on one end, inserted into the tank on the top fitting with a 90 degree bend. I route it through the fuel tray on to the PX side, bent around the shape of the outer hull down to the bottom of the firewall at the gear exit. Its then bent 90 degrees into the wind. I never liked the loops above the filler some builders have done, wanting a concealed vent instead. The only issue is if I fill the tank to the top and let it heat soak, I will get some overflow through the vent to the ground, but its dumping under the plane.
