Fuel Tank Vent..................?
Paul.......I also made my glareshield removable (a must do mod for sure) like you and David although I used an AN-4 fitting at the tank. Another mod I did was split the glareshield so the rear piece (about 7") is removable with out disturbing the fuel tank in case I need to get behind the panel for some reason. If you email me I could send you some pictures of this modification.
gdbaxter78@gmail.com Routing the soft 1/4" vent tube down through the glareshield and down through the left front corner of the floor was not difficult and is easily removed if needed. Make sure you protect the tube with some clear plastic hose where it passes through the glareshield at an acute angle.
David.....yes I remember talking to you (and Tom Jones as well) at Oshkosh. Hope your Onex is living up to your expectations.
Gordon......Onex......Hummel 2400
