NWade wrote:[However, the Aerovee and the Turbo still appeal over the alternatives in the following ways:
- Cost: The Rotax, Jabiru, and UL Power engines are all 2 - 3 times the cost of a Turbo. The Corvair is the only other engine in its cost bracket.
- Weight: The Turbo is still under 200 lbs, whereas Corvairs are ~225lbs. The Rotax and Jabiru beat both by a handy margin; but then it goes back to the "cost" line.
- Zero-time parts: Corvairs are all "salvage" engines, right? A lot of folks (myself included) are uncomfortable with the idea of an engine block that's got no history and has been sitting out in the elements for an unknown length of time. You can inspect it in-detail and clean it up, but you can never know what it went through before you found it.
--Noel
P.S. The frustrated cynic in me is compelled to point out that I've got experience with zero-time parts that are still wrong or have failed. :-P
peter anson wrote: Would it be possible to solve the turbo oil coking problem simply by running the engine at low idle for a while before shutting down? I know it's not as convenient when whizzing propellers are involved, but I often sit in the aircraft for a few minutes after I shut down while I fill out my log book so having the engine idling wouldn't be too inconvenient.
daleandee wrote:"lots of engine comparisons"
Brett wrote: Just a note as per your first post, when the turbo is seized on take off you CAN still climb with the cruise prop. Climbs at about 180-200 fpm at 27" map, as stupidly I have done it.
peter anson wrote:I have a dumb question from a non-turbo flyer. I recall that when turbos first started appearing on cars they sometimes had an arrangement where after you turned off the engine, it continued to idle for a few minutes while the turbo cooled down and then shut off automatically. Would it be possible to solve the turbo oil coking problem simply by running the engine at low idle for a while before shutting down? I know it's not as convenient when whizzing propellers are involved, but I often sit in the aircraft for a few minutes after I shut down while I fill out my log book so having the engine idling wouldn't be too inconvenient.
Rynoth wrote:Basically, I'd like to opt out of being a card-carrying member of any "Turbo Fiasco Club" for the time being, and fully intend to ride behind my Aerovee Turbo for my first flight (Coming Soon!)
Rynoth wrote:daleandee wrote:"lots of engine comparisons"
Dale, I’m just quoting you since you're the most recent post, but as the OP of this thread I'd like to steer this conversation away from engine comparisons and back onto Aerovee Turbo, specifically the Turbo SB and coking issues/solutions/experiences.
daleandee wrote: If you want to focus extensively on the actual opening subject you might have a bit of difficulty finding very many turbo users that had a seizure before their first flight.
Users browsing this forum: Google Adsense [Bot] and 5 guests
